jrnymn7
May 10, 2015Explorer
"So I don't see how Voc would help to determine how it will charge a battery."
As I understand it,
1) Voc is always > Vmp. I can see low light conditions causing Vmp to approach Voc. However, at no time can an mppt controller charge, using Voc; as that would reduce current down to zero amps.
2) PWM controllers (edit: use up to and including Voc, in low light conditions), which is maximum panel voltage at that moment, in those particular conditions. And provided it meets Kirchoff's voltage law, charging will commence.
As I understand it,
