CA_Traveler
May 11, 2015Explorer III
jrnymn7 wrote:Well you need volts to be above the battery in order to charge. Then amps and volts (or watts) both come into play so that MPPT can provide the increased battery amps for the given battery charging voltage.
Seeing as mppt use watts, it seems to me an increase in watts would be required; not an increase in voltage, necessarily?
Perhaps there are just different ways to view how the charging gets accomplished. :@
