SoundGuy
Jun 05, 2015Explorer
1775 wrote:
These little inverters are not intended for what some want to power with them.
But still (try to) do it anyway. :S
For those who do want to do it right the solution is simple - just refer to a DC Wiring Chart like this that will tell you what gauge and length of cable is required for the maximum load you intend to draw. Since I (current in amps) is calculated by dividing P (power in watts) by V (volts, in this case a nominal 12 vdc) it's easy to calculate the correct wire gauge - e.g. a 300 watt inverter drawing full load would draw 300/12 = 25 amps. Look at the chart and that will tell you what gauge cable you need for the length you want to run.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
