hotjag1
May 02, 2023Explorer II
Thank you to all for the explanations and suggestions. The gasket has no frost or ice around it and appears to be in good shape with no cracks or loose areas.
I have modified a screwdriver to 90 degrees and can fit it in between the door and the freezer frame to release the gasket pressure. It works fine that way but I'd rather not have to do that.
Where would I drill a small hole to relieve the vacuum pressure? I don't see any factory relief valve. It is a Dometic.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
