hotjag1
May 03, 2023Explorer II
It is the freezer portion of the refer. The model# is RM3863.
It's not that big of a deal to use the 90 degree screwdriver, just hoping there might be a permanent solution to release the vacuum pressure.
Just not sure if drilling a small hole in the door jam would work although it sounds feasible.
The gasket does compress and seal properly.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
