ktmrfs wrote:
JimK-NY wrote:
Vintage465 wrote:
Yup that is true you would have only 235ah in a two 6-sixer set up. But you'd only have 200ah in two-12er set up and they both have the same "safe draw down to 50%". The weight is about the same, the sixers being about 2 pounds heavier. The 12's will take up more space as their foot print is a little larger.
I found 2 batteries that compared closely for AH ratings. The first was a 6 v Duracell @235/2=117 and the second was an Apex 12 v with 115 AH. Two of each would be comparable. The weight for each was identical @ 68#. The 6 v took 794 cu in of space and the 12 v tool less at 729 cu in. The biggest difference is in height of the batteries. Typically 6 volt batteries are higher, in this case by almost 3". My battery box will not accommodate the extra height so for me there is no choice but to stick with a pair of 12v batteries. At least I found a pair totally 300 AH that will just fit.
the height increase with GC2 is an issue with a fair number of applications. And couple that with few vented boxes for GC2 use in 5th wheels.
However for tongue storage there are many nice boxes made for two GC2's either end to end or side to side configuration if you have enough clearance to get to batteries in. But that assumes the TT battery location on the tongue has enough height, and on many new trailers that can be an issue.
In my case,(and everyone's situation is different)the height is not nearly as much an issue as is the foot print. It would be nearly impossible to get the amount amp/hour with 12v batteries and get them where my 6's are.
