mr_andyj wrote:
No reason to even consider NOT using two 6's.
Use two 6's!
No reason to not consider two 6V is a VERY VERY MISLEADING AND POOR STATEMENT!
reasons NOT to consider two 6V
1) seldom boondock or dry camp, a single or pair of 12V will be more than adequate and be less expensive in the long run.
2) You want to have high current draw for big inverter loads, e.g. run a microwave, coffee pot etc. or other loads more than about 50A. For these a 6V is NOT a good choice, high internal resistance and no current load sharing with a single bank is an invitation for inverter shutdown at about 80% SOC, while a pair of 12V will really not have much voltage drop, each battery is only supplying 1/2 the current and with more thin plates has much less internal resistance.
Alternate solution is Four GC, but that takes up lots of space, expensive and heavy.
3) Battery compartment won't fit a pair of 6V. There are trailers where 6V are a very very tight fit and the hassle may not be worth the effort.
So YES THERE ARE VERY VALID REASONS WHY A 6V IS NOT THE UNIVERSAL END ALL BE ALL SOLUTION!
STATEMENTS LIKE YOURS ARE WHY PEOPLE MAKE BAD CHOICES ON BATTERIES!
Each battery type has + and - attributes, gain something loose something. Good when you gain what you want but bad when you LOOSE what is important to YOUR specific application.
