mrekim's avatar
mrekim
12x2" Brake differences
I have 5200 lb axles. I'm about to start working on the brakes to deal with a short (according to the brake controller).
I'm considering getting some self adjusting brakes. I see that I can get filled backing plates for 12x2 brakes at 5200 lbs, 6000 lbs, and 7000 lbs.
I've also seen 12x2 brakes for all these rating (5200 through 7000).
Does anyone know the how these differ?
[EDIT]
I found this:
ETrailer FAQ Item
So it seems that all 10x2 should interchange with the higher rated ones have a stronger magnet and different pad compound?
Also, I would assume that if you go to a different magnet/compound you MUST do both wheels on an axle and probably should do all the wheels to keep the braking as even as possible.
[/EDIT]
  • j-d wrote:
    You may be past this, but adding to the above quote...
    I'm told the inside of the axles develop rust and the rust flakes chafe through the insulation of the brake wires. Better to run them on the outside. On my boat trailer, I've found electrical tape lasts longer than ZIP ties for holding the brake hoses to the axles. I suspect same'd be true for wires.
    Since I boondock, I'd much prefer the wires inside the tube... Never had any issues with that at all. Sagebrush etc. will snag any exposed wires such as those zip tied to the outside of the tube.
  • westend wrote:
    Very likely. I'd suggest to pull the original wiring and wire the brakes using a Star configuration.
    I now have a star configuration. Each wheel has a 10 gauge drop from the frame at the wheel and then they all connect at a bus bar near the rear axle with a 10 gauge run to the front. These are all protected by the plastic corrugated bottom cover. I cut an access hole to get to the bus bar.
    This should be much better than the 14 gauge.
    I'm hoping the springs provide some protection for the wire where they drop through the corrugated plastic. I don't offroad with the trailer so road debris would be my main concern.
