CJW8
Aug 05, 2016Explorer
2oldman, with the numbers you are giving you are recirculating cold air. In otherwords, a lot of your cold air is getting sucked back into the intake. That is the only way your indicated delta T you are stating is possible. Or your measuring device is incorrect.
The difference between a 13.5K and a 15K is 1.5K. An air conditioner really is a heat remover. So the 15K will remove more heat. (BTU is a measure of heat) It does this by moving more air across the condenser and the evaporator, having bigger tubes and a larger compressor and probably a different orifice or expansion valve. I am certain many things are different between the two units. The temperature difference (delta T) between the intake and the outlet will always be 18-22 degF on a properly functioning unit with the technology we use today. The air mover in the larger unit will probably move more air.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
