dougrainer
Aug 15, 2016Nomad
greenrvgreen wrote:
Chris, I guess I haven't understood one bit of it either, especially the part where you resort to name-calling, instead of explaining clearly what you see as the problem with Oldman's temp readings.
AFAICT, he has a thermometer at the intake vent, and again at a remote outflow vent. If you're saying the cooled air is short-cycling and re-cooling, how is it doing that? The two readings are remote from each other.
While Oldman hasn't been easy to deal with here, his assertion is clear and no one has yet made a clear answer to it: Why is he getting these readings, is it a clear case of insanity?
So, you would be fine with your Doctor using those type Thermometers to gauge your health? WE cannot answer his question because we have no idea how his system is installed and what may be happening. A Blind Hog will eventually find the Acorn. But, not ALL blind hogs will find them in the same amount of time:B Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
