Bob_Landry
Aug 15, 2016Explorer
They are not "contaminating" each other as they are spaced out. Cold air is likely being drawn directly back to the return side in the discharge plenum(lower unit)usually the result of a poorly done installation. Drop the cover on the AC and stick your hand up into the plenum. If you feel any cold air at all, it needs to be sealed off/re-taped.
"Since I've only used my hand to gauge delta-T I have no idea what a ~20 degree drop should feel like."
And you will not be able to gauge it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
