red31ExplorerApr 01, 201413.6vWith enough time, will 13.6v (75F) charge get to 100% SoC, return sg ...? 6v golf car? 12v marine DC?
Road_RunnersExplorerApr 01, 2014It will get there at that voltage. I am assuming that your 6V batteries are hooked together in series to give you 12 volts.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
Related ContentRe: Can i replace a 55amp converter with a 35amp converter in motorhome if i only use it a few times a yRe: Solar panel and battery noiseNeed Solar Guru Help!Re: LiFePO4 Converter Change?Re: Plugged in or Trickle Charger
