naturist
Nov 06, 2015Nomad II
I'm not surprised. That AC size will pull right around 2000 watts when the compressor kicks in, some a little more, some a little less. Sounds like his is a little more. Being right at the cusp, so to speak, is why sometimes folks can get a 13,500 btu AC to work on a 2,000 watt power supply, and sometimes they can't.
Running an AC off a battery in any case is a bad idea because the total power load is so high. Much better is to use a generator, and I'd recommend at least a 2,500 watt one at that as a minimum, with 3,000 watt even better.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
