Chum_lee
Nov 10, 2015Explorer
otrfun wrote: "All the Dometic and Coleman spec sheets I've seen typically show LRA's of 50 to 68 amps for their 13.5k BTU a/c's."
Yes, you are correct, for several microseconds during startup. Think about what you know! If it took 50 to 68 LRA'a to start a single 13,500 BTU A/C unit, then the smallest RV generators would be 6,000 to 8,160 watts. You know that is not true. As I previously said, under certain conditions you can run a 13,500 BTU A/C unit on a 2,000 watt genny, just not reliably without playing a bunch of load management tricks. If thats what like doing, more power to ya!
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
