time2roll
Nov 10, 2015Nomad
Consider a transfer switch if you have power available at the shop or home where the van is loaded or sits overnight. If you could plug in a couple hours or all night to keep the van cool. It would sure help the cooling load during the day. Maybe even a small battery charger (15-20 amps) to make sure you are topped off before you head out. Utility power will be far lower cost than gasoline.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
