dougrainer
Jul 31, 2013Nomad
Beltone Magoo wrote:
Don't think those Dometic reps have been to the Houston area. I have a 41ft MH and the 2 13,500 btu units were not getting the job done. I replaced the front unit with a 15,000 as that is where all the heat was coming from thru the windshield etc. Now works good at keeping a decent temp in the MH. One concession I made was to set the thermostat to always run only on high fan speed. Hasn't frozen up yet. That was something I learned when I had a TT that would freeze up if the fan speed was lowered. FWIW I am just north of Houston off I45. Good luck and safe travels!
I do NOT believe that the Dealer has even talked to the Dometic reps. I deal with Dometic weekly and I can guarantee that Dometic would never state such nonsense. Your TT did not have a wall tstat and did not have a freeze control. ALL RV roof top units with wall tstats have a freeze control that regardless of the conditions will NOT allow a AC to freeze. Your current motorhome IF you have wall tstats will not freeze no matter what fan speed or temp you set. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
