wanderingaimles
Jul 24, 2022Explorer
Not trying to be snide, but did you check at the switch for voltage?
At least that will send you either to the lights, or back toward the fuse panel. And if none to the switch, can you run a new hot wire to it?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
