tommyznr
Jul 25, 2022Explorer
wanderingaimlessly wrote:
Not trying to be snide, but did you check at the switch for voltage?
At least that will send you either to the lights, or back toward the fuse panel. And if none to the switch, can you run a new hot wire to it?
This.
My awning lights worked for a year or so then stopped working. I finally got time to look into it last week and found I had 12 volts at the switch and about 2 volts at the light.
It turns out the wire from the switch to the LED lights was pinched in the ceiling, so much so I could not pull it through. I spent the better part of the weekend snaking a new wire through my ceiling to replace the old. Lights work like a champ now.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
