jwboudreau
Jul 25, 2022Explorer
wanderingaimlessly wrote:
Not trying to be snide, but did you check at the switch for voltage?
At least that will send you either to the lights, or back toward the fuse panel. And if none to the switch, can you run a new hot wire to it?
You aren't being snide, never thought of that, will have to check to make sure I am getting power there. Thanks, that is why I posted, looking for ideas to check before I just give up on it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
