klutchdust
Feb 15, 2019Explorer II
time2roll,
I measured the battery voltage and the connections at the inverter, both 13.4 volts. I turned on and was running the front Tv off of the house batteries and the house inverter and all was well for a few minutes then the high pitch whine started. I checked the battery voltage and it dropped to 12 volts already. My Trojans T-105 were purchased 8/15. Maybe they have are due to be changed.
One incident i am embarrassed to admit is last spring I checked my batteries and they were almost out of water. I am better than that. I filled with distilled water and they have been performing quite well but I wonder if that was the beginning of their demise.
Landyacht, I may just try that. I would have to come up with a plug similar to what is on the tv now.The inverter is hardwired to a wall switch.
After having a service port failure in my dining area charging my phone ,I reluctantly use those "cigarette lighter" ports or trust them.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
