time2roll
Feb 15, 2019Nomad
If the battery power went from 13.4 to 12.0 basically just powering this item then it would seem the batteries have severely diminished capacity or were not really charged. Although usually these inverters do not complain until you get to 11.0 volts or below. Yes have the batteries checked. Consider a bench test of the inverter with a known solid 12.5+ volt DC supply such as the chassis battery with the engine running.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
