time2roll
Feb 16, 2019Nomad
Yes you can do way better than the 7300. PD4645 is probably the best direct conversion replacement.
http://www.bestconverter.com/PD4645V-45-Amp-Converter-Upgrade
Need to verify the wire size to go more amps. PD9260-14.8 or larger would be fine if the wire is large enough.
http://www.bestconverter.com/9200-148
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
