BFL13
Feb 18, 2019Explorer II
With those batteries being not so bad (they do need equalizing at 16.2v to tidy them up) you can repeat the OP inverter experience with no shore power (and so no converter) and see what happens.
Then do it on shore power but with the battery bank disconnected. that will test the converter.
There is no reason given to suspect the converter at this point IMO.
The OP suggests it is a wiring/connections issue with where the inverter is connected to its 12v input, and not the input source itself.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
