BurbMan
Jan 28, 2014Explorer III
14V TV?
I swear I just saw a thread on this but can't find it now.... Looking at Samsung 24" LED TV for the bedroom that has an external power brick. The power connection on the back of the TV is labeled ...
BurbMan wrote:Using an inverter is less efficient BUT if you're using more power without the inverter, what's the point? Also, any reason you must have a 22" TV? Here's a 24" that draws 27.5W: Vizio E241i-A1W - Best Buy. If it's like my TV, it will draw less than that (mine is rated 33W on their site but I found that was just startup draw...it dropped to 20-24W during use).
So, I could keep the existing inverter set up but thought it would be more efficient to wire directly and cut out the inefficiency of the inverter.
