Dusty_R
Feb 19, 2021Explorer
Gjac wrote:
Does your genset seem like it is running at a higher rpm than normal? You can buy cheap HZ meter plug it into your 120 v socket and adjust the speed to read the correct HZ at the proper rpm.
Look and see what the output voltage is supposed to be. At that voltage it is also running at 60 HZ, this has to do with the building of the generator.
So using a decent volt meter will do.
If there is an adjustment on the governor I would try slowing the engine down while watching the output voltage, setting it at or a whisker over.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
