SHRED
Feb 19, 2021Explorer
dougrainer wrote:
AC Output
Voltage Too Low
Or Too High
Noisy Generator
Possible Cause
1. Open circuit breaker
2. Open circuit between brush
block an CR4 rectifier
3. Brushes stuck in holder or
not making good contact with
slip rings
4. Defective CR4 bridge
rectifier
5. Open, grounded, or short
circuit in rotor, stator, or
transformer
1. Engine governor incorrectly
adjusted
'2. Open diode in CR4 bridge
rectifier
*3. Brushes worn or not making
good contact with slip
rings
4. If generator frequency is
within specified limits but
voltage is incorrect,
transformer is incorrectly
connected or defective.
'5. Open, grounded, or short
or transformer
'causes low AC output voltage
1. Loose brush holder
2. Worn generator end bearing
3. Rotor and stator rubbing
together due to: a) varnish
lumps, orb) rotor
misaligned with crankshaft
Corrective Action
1. Locate cause of overload
and correct as required.
Reset breaker
2. Check for continuity and
correct if circuit is open
3. Release brushes if jammed
in holder. Clean slip
rings if dirty.
4. Test rectifier and replace
if defective
5. Test each component for
open, grounded, or shorted
windings and replace if
defective.
1.
2.
3.
5.
Refer to Governor
section
Test CR4 rectifier and
replace if defective
Check length of brushes
and replace if worn
excessively. Clean or
replace slip rings.
Adjust tap connections on
transformer secondary
windings to obtain correct
voltage. Replace
transformer if voltage cannot
be corrected with adjustments.
defective.
I didn't see "regulator" in there.
I'm getting to the point where professionals need to look at this mess I think.
I did unhook the ATSwitch and the breaker on the genset didn't trip off which was my original symptom.
Now I'm thinking the high voltage may have damaged the ATS.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
