SHRED
Feb 20, 2021Explorer
Gjac wrote:
If the engine governor/regulator is high to cause 170 v you would hear it reving high. First before you take it in, plug your volt meter into your house circuit and see that it reads 120 v or so just to verify meter. Is it reving high? Did you verify your meter is good? There is a company called Flight Systems that have helped me in the past with my Genset and other systems. If you call them 717-590-7330 and describe your problem they can help you fix it. They also have a troubleshooting guide for your genset on line.
My meter is accurate and the genset is not revving high.
Thanks for the Flight Systems tip.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
