SHRED's avatar
SHRED
170VAC coming from my Onan generator
It's a 1995 4000 BGE.
I posted earlier but wanted to focus in on this problem.
I tested the lead coming into the breaker switch and it was a consistent 170 VAC.
What should I check next and how?
Regulator?
Thanks
  • Governor! Does the genset sound like it is running overly fast?
    If you can see and get to the throttle linkage see if it is moving.
  • Gjac's avatar
    Gjac
    Explorer III
    Does your genset seem like it is running at a higher rpm than normal? You can buy cheap HZ meter plug it into your 120 v socket and adjust the speed to read the correct HZ at the proper rpm.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Jul 31, 2025
