- Governor! Does the genset sound like it is running overly fast?
If you can see and get to the throttle linkage see if it is moving. - GjacExplorer IIIDoes your genset seem like it is running at a higher rpm than normal? You can buy cheap HZ meter plug it into your 120 v socket and adjust the speed to read the correct HZ at the proper rpm.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
