BFL13
Nov 12, 2018Explorer II
I am assuming the 1 to 1.5 amps is measured at the batteries by say a Trimetric monitor. If the amps are from the controller's display, then that is a whole different story to figure out.
The blurb on the kit says it has 25 ft of #10 input and 25 ft of # 10 output wire which should be ok for the 8.9 amps it says it will do.
The controller is this one. Interesting about that boost button.
https://gpelectric.com/wp-content/uploads/2015/06/GP-PWM-30-UL_Manual-with-French_2018-04-10.pdf
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
