toedtoes
May 03, 2018Explorer III
The Mopar ignition system from that Era was notorious for failing. Most times, it was the resister that would burn out.
In my case, it was the resistor, the coil, the ignition module, etc. It would just fail to start at random times.
The GM mod replaces the mopar ignition module and resistor (which provide a stunted spark to the distributor) with a GM module only (full spark). So you eliminate the two most common culprits of failure.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
