toedtoes
May 03, 2018Explorer III
I think your problem is different.
Sounds like someone rewired to run the house off the engine battery. Most RVs keep them separated except for charging purposes.
Personally, I would rewire it so the lights work on the house battery only and not install a switch. No sense in running down your engine battery.
I have a diagram that shows how to wire it so you can jumpstart your engine battery from your house battery with a flip of a switch. Normally, the wiring just allows the house battery to charge off the alternator when driving - and that wiring was usually done with a too small wire.
If you'd like that diagram, PM me with your email and I'll send it to you tonight.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
