j-d
Jul 27, 2017Explorer II
When it's in Start Mode, the Control Unit bypasses safeties like oil pressure and checking for output. When you release the switch into RUN, Control starts sniffing around for problems. I suspect it's either
1. Finding something actually wrong, and protecting you from the consequences or
2. Keeping you from having A/C because it thinks something's wrong that isn't
A bad fuel pump is always a possibility. There's probably a generic replacement that bolts right in. We had a BFA and I replaced ours with a little Purolator generic. There are "Standard (sometimes called High) Pressure" ones 5-7 PSI and "Low Pressure" more like 3 PSI. BFA calls for "Low" and it worked fine.
Do you have a Service Manual for BFA? I kept mine, and can scan the troubleshooting pages for you if you like. PM me with your email ID.
