TEXAS
Aug 26, 2016Explorer
Irish Spring works better than Ivory.
Go to the auto parts store. Pick up a can of Carb&Choke cleaner. With the red nozzle. Remove the top of the carb then remove the float an needle. Spray the inside of the carb bowl and the body of the carb. Spray the passages. Then blow it out with air.Unless it is really clogged up this will clean it out. I can send you a breakdown of the carb. If it will help.
I no longer trust Onan shops. Heard from to many people getting ripped off. Onan is not what it used to be.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
