jllaco
Jul 15, 2014Explorer
My model info is not on the generator so I am not sure at it is a bge. It is a 4000 watt Emaerald I genset, that I am sure of. In the manual I saw online it said I should have about 4 ohms across the low voltage leads, mine are shorted and it says around 15000 ohms on high side, mine is 15 ohms.
I might go ahead and buy a coil but I have no idea what the part number is since I do not know the model number.
FYI, the negative terminal has two wires, one is going to a nearby small silver cylinder , condensor maybe, and I have not traced the other back. I am getting 12 volts at the coil,actually slightly less but basically the same voltage as at the fuel pump
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
