Grit_dog
May 09, 2021Trailblazer
While it could be due for hoses and you’re right, why would a cooling system overhaul not include replacing presumably very old hoses, my money is on fan clutch.
Do you hear it roar as temps are rising while underway? If not, that is telltale.
I’d either replace fan/clutch again, or totally eliminate it from the equation and slap a flex fan on it, at least temporarily.
Remember the clues. It was fine until the incident last year. And sounds like the fan and water pump were the only mechanical parts, if you will, that were replaced.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
