ThorValhallan
May 10, 2021Explorer
Yep Gjac, we just did a sheet of paper test to confirm. It is pushing air out of the radiator. That explains why it was running cooler yesterday, I had the doghouse cover off the whole way home watching things, so it was sucking air in thru the coach. We're going to call the shop here in a minute to confirm the P/N on the water pump, but I'm betting this was the original issue. I'll update later when everything else has been sorted. I also still want to confirm the initial timing after this is all done, because lord only knows the last time that was checked.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
