trop-a-cal
Oct 19, 2013Explorer
1997 454 GM vortec motor problem with EGR Valve
I noticed the idle down lower than normal and a weak start. Then a pinging, and loss of power after a full up when tank was almost empty. I was told the exhaust system has a valve, that recycles exhaust fumes from gasoline, that can stick causing these problems, which are then worse and shut the engine down completely due to the valve sticking open. And so it happened and in to the shop it went and is. The engine started knocking after the pinging, but full power was there when it ran at interstate speeds. It did dog and have low idle when at low speeds and at stops. EGR Valve- Exhaust Gas Return Valve, is its name. Tell me if your 1996-1999 Chevy vortec did that and was cured with new valve and at what cost. Thanks
