- MrWizardModeratorI'll check those out, thank you
- 72cougarxr7ExplorerNapa part # 1348 or Wix 51348 should work
- Bayles859Explorer
Thank you cougarxr7
- STBRetiredExplorer
- MrWizardModeratorFL400S
Perfect fit , and sticks out enough to get a grip on
Used a wrench from my 'cap' style set of filter wrenches to remove the old one only way to get it off
Now to find a replacement fuel/gas filter
Little screw in metal jobby - MrWizardModeratorSTB thank you
- STBRetiredExplorerI have the 5BGM model generator. It had the 122-0800 oil filter installed in it. That is the substitution list that I shared in the earlier post.
- MrWizardModeratoryes it looks like that, the last letter in the Model number is different
that might indicate year ?
but otherwise yes thats it
thank you - RLS7201Explorer III believe you generator will use the same oil filter as my 7K NHM.
I use a Motocraft FL400S from Walmart. The FL400S filters are a little longer. Makes removing easier.
Does your generator look like this?
If so the FL400S will fit.
Richard - STBRetiredExplorerFound this Oil Filter Cross Reference When I was looking for a replacement for my Onan oil filter.
- MrWizardModeratoryeah i know, NAPA is simply a rebrand
if i get a NAPA number anyplace can cross reference it
or i can do it my slef on the web
