Sam_Spade
Jun 06, 2016Explorer
heebeha wrote:
I have to keep it throttled to start it and keep it throttled for a while till the automatic throttle control kicks in. It seems to do a fair job at keeping her at idle until you either manually touch the throttle arm or try put her under load.
I did not realize the generator used the truck battery verse my campers deep cycle battery to start it.
Now we have a different story from the original "won't start".
But all of the stories point to a carb problem (way too lean or choke not working) and my Onan dealer replaced my carb for about the same price as a removal and cleaning which doesn't always work. Highly recommended.
And as for the batteries: The gen starts off of the house batteries BUT when the truck is running a solenoid closes to connect both sets together.
My guess is that you need a new carb on the gen AND you have a bad connection from the house batteries to the gen OR the house batteries are getting old and weak......or are not being charged properly.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
