heebeha
Jun 06, 2016Explorer
I disconnected the Cut Off Solenoid Valve red connection and it died. Then I connected a straight positive lead to it and it fired up after again having to play with the throttle. I tried disconnecting it and reconnecting it when it was running to see the effect and the throttle killed it but when I reconnected it the generator came back to life. Does that Cut Off Solenoid Valve work in conjunction with the governor to keep her running during a surge ?
Could it be my problem?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
