Sam_Spade
Jul 08, 2016Explorer
heebeha wrote:
Any ideas what could be wrong, solenoid maybe?
Once running it runs great but is very loud.
NO.
Maybe you don't understand engines at all.
Not meant to be an insult; just fact based on the evidence provided here.
The typical Onan onboard has a "prime" switch, often the same one as OFF. Are you using that for a full 30 seconds BEFORE trying to start the generator ?
Are you sure that major loads are turned OFF while starting ?
Hard starting could also be a sign of needing some carb cleaner in the gas; Berrymans B12 Chemtool is probably the best.
It also could be a sign of the choke not working right.
Is there a good reason why you are NOT going to visit a Cummins/Onan dealer to get this fixed ???
The noise could be a loose exhaust manifold or burned out muffler.
If there is an exhaust leak, you could have a carbon monoxide hazzard to your health.
