ChaosAgent's avatar
ChaosAgent
1999 American Eagle Vent Fan Fuse
Recently had guys replacing both of the roof vent fans on our 1999 American Eagle coach. They accidentally shorted the  power wires together on the rear (bathroom) unit. So spark, no more 12 VDC.
Front unit still works fine.
Checked the fuse panel at the bottom of the bed with no luck. All seem to be good.
If it's up front by the steering wheel, nothing is labeled that way on the diagram.
Anyone have any ideas?
Thanks in advance.
  • Another logical plan. Sure wish the electrical panel and guts could be somewhere other than at floor level.
  • did you pull each fuse out and check with a multimeter across the plugs?  some times it can be hard to see and almost impossible with out pulling them, unless you have the light up fuse indicators.
  • Check ground continuity and + from fan to fuse.
    it should have blown the fuse immediately but may have taken out a weak wire instead.
    • ChaosAgent's avatar
      ChaosAgent
      Thanks for the reply. I already ran a separate 12 V wire to the fan and it works fine. So not a ground problem.
      Thanks again.
