MEXICOWANDERER
Mar 21, 2016Explorer
Are the camshaft sprocket teeth steel, or nylon? Back in the sixties when I wrenched, I decided around 90% of timing chain faults were due to the nylon teeth on the factory cam gear and the failures had nothing to do with the chain or steel crank sprocket.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
