Chum_lee
Apr 19, 2018Explorer
KevinDale wrote:
Hello all I am new to this forum, I was looking through articles a while back and saw where someone on here had the same issue and was wondering if anyone could help me out.
this all started because I need a new steering column I broke the steering wheel removing it and the clock spring as well I am confused as the term clock spring being used because I have no airbag it appears it is for the horn.My clock spring has four bolts coming off of it there is no spring there just contacts on the back side for the horn and I'm assuming turn signal to catch.
And The Main Issue I Have Is Needing A Steering Column.Man Finding Parts For This Thing Gives Me A Migrane, Spending More Time Looking Than Working.
Thanks
Kevin
The Ford F53 is the most popular class A gasser RV chassis out there. At the age of yours, the Ford Dealers may not be able to help you with everything, but, factory parts, especially steering/suspension have lots of commonality with other Ford models and years. Have you tried a Ford truck dealer? If they can't help you, there are hundreds of salvage yards out there that can if you are willing to buy used parts. Google is your friend. I'm sure you could buy a complete used steering column if you look in the right place.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
