poncho62's avatar
poncho62
1999 Keystone Springdale....slide problem
I bought this trailer cheap as it needed some work. Mostly fixed up now, but the small slide where the couch is seems to be loose. It is a manual slide, which I crank out from outside. It comes out no problem, but when I go to crank it back in, it seems to bind at the top. Its almost like the framework that it sits on has dropped or is broken inside. I have to crank it in and push the top part in as I crank it. Good thing I am tall...lol
When its all the way in, the top is still out an inch or so...and the whole thing seems to sit crooked
All I can see underneath is a large screw in the center that it rides on. The rest is covered by the black mesh. Anyone have any ideas how this all works before I rip it apart
1 Reply
  • Can't be of MUCH help but check carefully for signs of water intrusion. This can swell the wood frame around the slide room causing it to bind under some conditions.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
