Fishinghat
Dec 29, 2015Explorer II
Two 6 volt batteries are a better choice for "house batteries".
Six volt batteries have three cells, which are larger with thicker plates than a 12 volt battery, which has six cells. So, the 6 volt battery will tolerate discharging and charging much better than the 12 volt.
Starting batteries should be 12 volt, even if you have two as most diesel pusher coaches have. They work better as they provide high amperage for a very short duration and then are recharged.
