pianotuna
Jan 02, 2016Nomad III
Hi,
Also known as a surplus acid AGM. That means it can be seriously damaged by discharging too low. I believe they more or less ought to be treated as flooded batteries but carefully charging below the gassing voltage.
I'm using 4 of a slightly different rating to give me 566 amp-hours @ 20 hour rate (6.95 amps per jar). So far they have not objected to any load I've put on them. I will know more in a year. Charging rate is limited to c/5 or about 28 amps per jar.
I see that yours are listed as 145 amp-hours at the 8 hour rate (18 amps)
The 1 hour rate for mine is 95.5 amps. That suggests to me that I could do 4 times that (382 amps) for 15 minutes.
NinerBikes wrote:
Big Battery, AGM, low dough, big bang for the buck. YMMV, it won't run a big inverter, make electric coffee or run a hair dryer, but if recharged immediately, daily, and treated properly, not neglected, it will last a long, long, long time. Perfect for dry camping, forget it if you are a pedestal queen. This is a battery that likes long, slow distance discharges, forget the surges or blasts of instant high amperage energy discharge that NiMH and Li Ion batteries are so pricey and good at.
Teleccom AGM 12V 145 AH.
Should you care to learn how to properly dishcharge and recharge /maintain your RV batteries properly, here's a good read on the subject.
Care, use and recharging your RV battery by the book.
