brulaz
Jan 06, 2016Explorer
My understanding is that a higher plate surface area reduces voltage drop for a given load.
So for a fixed amount of lead, you can go either for dense plates and long life times (like GC2s), or thin, multiple plates with more surface area that can generate more current with less voltage drop (like marine/rv). Or you can compromise somewhere in between.
The no compromise solution is to have lots of lead, enough so you can have both, dense plates and lots of surface area (6-8 GC2s for example). Long life and little V sag under load.
