wittmeba
Dec 22, 2013Explorer
Don't try it! Don't even think about trying to make a box that will combine 2 20 amp plugs into 1 50 amp receptacle.
It is too likely (I'd bet big money) that the 2 20 amp connectors (a duplex outlet) are wired from the same wires from the distribution panel meaning you may only have 20 amps total available from a duplex outlet due to the feeding circuit breaker.
Most duplex outlets come from the factory with the lines of the top and bottom outlet connected together and the neutral of both top and bottom outlet tied together.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
